Oil smells bad like gas...
When I shift my car from first to second and give it gas it sputters, until I get it over 2K-2.5K RPMs. What is my issue? no CELs?
spark plugs, etc. Also you may want to get your injectors cleaned/squared away.
Do you have a compression checker ? Test the compression, see if teh head gasket is blown in one cylinder, doubtfull, but a possibility no less.
Could be some other things, but apparently you are so rich the gas is settling into the oil on the compression or intake stroke.
Rod
Rod
PanzerWagon
11-01-2006 06:45 AM
