Oil temp higher than usual....
I noticed that my oil temp has been up to around 220-225 on normal driving, i am using 5w30 mobil1 and a mann oem filter. I just did timingbelt/water pump/termostat maintenance. any ideas what would cause this? Before i did all this maintenance, my car would run at 200 and only go above during hard driving conditions.
naughty boy
<center><img src="http://pictureposter.audiworld.com/39785/bleed.jpg"></center><p>Loosen and raise the coolant expansion tank ~4 inches and then:
Loosen coolant hose on heater core and pull back hose sufficiently so that bleeder hole (arrow) is no longer sealed by connection.
- Top up coolant until it flows out of coolant hose bleeder hole.
- Push coolant hose on connection and tighten.
- Install coolant expansion tank cap.
(Yippers info)
(Yippers info)
