oil warning light revisited
well whoever stated look for leaks you were right on the money, i got my new oil filter today and changed the oil. i thought i had found the problem to be an off the shelf filter, but after i changed the oil and cleaned all excess oil off the oil pan i went for a short drive(app 10 miles). when i returned home i jacked her up and the pan was once again covered. the strange part is that even with the car jacked up on the left side the leak runs to the front left corner of the pan. i suspect it is coming from behind what i assume to be the oil cooler, it is the square box that the filter mounts to. any thoughts?
Catamount90
19
02-29-2008 08:38 AM
StreetCrawler(Cole)
06-13-2005 11:15 AM
