Ok, it is 110* outside, how do I remove the drivers side fog?
I searched and mostly came up with removing the bulb. But I want to remove the whole housing.
Thanks.
Thanks.
pull the plastic covering straight off, then 4(?) screws will be in plain sight.
unscrew those and you can pull out the foglight housing.
by the way, if you searched and found out how to remove the bulb, wouldn't you also have found out how to remove the housing? cuz you can only replace the bulbs by taking out the housing.
HighPSI
08-26-2003 12:05 PM
Wren90q
06-05-2003 07:57 PM
T-Man
04-16-2001 06:23 PM
