ok a few ?'s for those with 4 point harnesses...
am I correct in assuming that most if not ALL sholder harnesses attatch to the rear bench seat..if so what do you guys do with them if you have some one ride in the back seat????
thnx
thnx
trick is to get a rollcage with a bar behind the front seats ;)
<center><img src="http://pages.infinit.net/veritech/A4/rollbar-1.jpg"></center><p>..getting my harnesses soon...
regards,
Liam
regards,
Liam
I assume this prevents you from moving the seats back?
Do you put the cage in with the seat all the way back, so that you retain the range of movement, or do you put them in whatever position you use and then not move the seats anymore? I'm just wondering how "livable" having the cage is.
It depends how tall you are...
My friend who sat in my car is 6' and to move the seat back, he had to put the backrest almost completely vertical (perpendicular) to the ground.
So to answer your question, NO, you can't put the seat all the way back like before, but it is still liveable (both for the passengers and the driver).
Best solution before going to the all-out-track-car setting
regards,
Liam
regards,
Liam
bellevue rs4
RS4 (B7 Platform) Discussion
10
08-09-2006 09:11 PM
saabSean
11-15-2004 09:00 AM
kkemp
01-18-2002 10:50 AM
srosie
12-17-2001 04:21 PM
