ok...just added a CD changer...recoded...not working WTF?
I installed a panasonic cd changer, i have the bose stereo.
I followed this <a href="https://forums.audiworld.com/a4/msgs/1114392.phtml">link</a> for recoding...i tried 00107 and 00117. the original coding was 00115.
the CDC button is not lighting up. a cd is in the changer. actually a CD-R. would that matter?
also, the panasonic changer came from a fellow AW'er with an adapter cable....i didnt use this, is this the problem?
Thanks
Thanks
a) the adapter looked like an extension cable
b) the cables from the car and changer connected together perfectly
c) blah blah...
apparently the "adapter" adapts the changer electrically, not physically (as i expected)
c) blah blah...
Usually these name brand changers will work with a factory head unit if you swap two of the pins on the harness. That's usually what these adaptor cables do.
If you search, you'll find the pin diagram, and a notation on exactly which pins are swapped in order to get the changer to communicate with the head unit.
tt-3
12-07-2002 12:41 PM
brrman
07-24-2002 01:42 PM
KeremD
10-07-2001 08:42 PM
Bruck
01-22-2001 11:31 AM
