opinion on asymmetrical tires IE Pirelli PZero Nero M+S
I just purchased these with my flix artics and when i put them on the car i realized that they are basically a completely different tread pattern on the left than on the right. I did some research and found out they are made that way but an curious as to how they work. Is there a side that works better? When turning left the tread is going \/ but when turning right it goes /\. Did they design it that way or are they lazy and just designed the tires and then said ok just use them on the other side as well?
all 4 tires are the same and all are mounted with the tires outside wall labeled "OUTER" I check with Pirelli and they said this is correct.
