Ordering ECS ultimate timing belt kit.....
but you need
timing belt
relay roller
tensioning roller
hydraulic tensioner
its also good to do the
thermostat
water pump
ribbed belts
at the same time to get it out of the way.
timing belt
relay roller
tensioning roller
hydraulic tensioner
thermostat
water pump
ribbed belts
you should purchase the following to be thorough:
Timing Belt
OEM Tensioner Roller
OEM Tensioner w/small roller
Water Pump With gasket
Thermostat with O-ring
A/C Belt
P/S Belt
Water Pump Belt
OEM/Pentosin Antifreeze
Another good place to buy all this is:<ul><li><a href="http://www.germanautoparts.com/">GermanAutoParts</a></li></ul>
Timing Belt
A/C Belt
P/S Belt
Water Pump Belt
