outer tie rod end frozen -- any advice?
Old 12-31-2005, 01:18 PM
New Member
Tthomas's Avatar
Default outer tie rod end frozen -- any advice?
Trying to change my outer tie rod ends and the outer tie rod end is frozen where it screws into the inner tie rod.
Have soaked it in liquid wrench for a few hours which hasn't helped.
Any advice on how to get the sucker out?
I have a propane torch, should I be careful applying heat to it? Obviously there's the plastic boot to be careful of but is there anything inside the inner tie rod I could melt?
thanks!!
Tom
Old 12-31-2005, 01:21 PM
Im@wesome~ out!'s Avatar
HEAT! .. use the propane torch.. will help.
Old 12-31-2005, 01:40 PM
Member
TANMAN's Avatar
Default PB Blaster and Vise grips......
That's what I had to do on my right one.
Old 12-31-2005, 01:58 PM
New Member
Tthomas's Avatar
Default did you guys thread the 22mm locking nut all the way back and use it for leverage...
or did you pull on the outer tie rod itself? (it flexes so its difficult to get a good "break").
Tried the propane torch, how long should I hold it on there for?
thanks!
Old 12-31-2005, 02:08 PM
Junior Member
k2enemy's Avatar
Default be careful threading it all the way back
the threads stop before you get to the end and you may strip the nut if you push it past the threads. i cut slots in a few washers and slid them on so the nut was still on threads but jammed up against the end.
actually, that didn't help too much because i was pulling so hard the nut started to strip while on the threads. i think i'll end up replacing the inner as well. there's no way that thing is coming off (while still on the car)
Old 12-31-2005, 02:20 PM
bassed-ndzmorezone5's Avatar
Usually ends up being the route taken (not by choice).
Old 12-31-2005, 02:32 PM
New Member
Tthomas's Avatar
Default thanks! I had started to do this but it looks like I didn't damage it. Good idea about the washers!
If I don't get it off by tomorrow I think I'm going to order a set of inners. What a pain.
Old 12-31-2005, 02:39 PM
Member
77'911's Avatar
Default A couple comments....
It takes awhile for liquid wrench to be effective, I find its more effect if left overnight.
If your going to use a torch, use the one in the "yellow" bottle which has a hotter mixture then the blue. The heat will 9 times out of ten, break it looose easily.
New Member
Tthomas's Avatar
I'll give it another go... it hasn't budged yet even after using the torch a few times.
Old 12-31-2005, 03:35 PM
njskier (A4i)'s Avatar
Default I ended up totally busting the whole outer TRE
which made it pretty much impossible to remove. Ended up bringing to the shop and they had to remove both the inner and outer to get it lose.
Is it your passenger side?
Quick Reply: outer tie rod end frozen -- any advice?
