Overheating issue. Overflow. Cooling fan.
Hi I have an issue with my car and part of it is that the auxiliary cooling fan isn't working properly. On most cars if you shut off the key and it is still too hot then the cooling fan will still come on. On my 1997 A4 it does not. Does anyone know what controls this function of the fan? Please help.
I was afraid of that. I already replaced the water pump. the one i pulled out was metal and so was the new one I put in, the gasket was leaking though, so not a total loss. My new plan is to replace the secondary auxiliary fan relay, and engine fan clutch.
This particular car has multiple problems. Then engine is very worn and really should be gone through and reconditioned; however, I think that my problem can be band-aid-fixed with a new secondary-speed auxiliary fan relay, and a new engine fan clutch. You may want to look for a short in the wire somewhere near the fan, but I don't know much about the wiring for the auxiliary fan.
Good luck.
Good luck.
Well if the car is overheating there's another problem. It shouldn't have to use the secondary and should be able to keep itself cool with the clutch fan. I too have overheating issues.
The switch that control the Elec fan is on the lower drivers side of the radiator. Its a three pin switch. Brown is ground, center is low speed and last is high speed. Worst case you can bypass the switch and wire in a fused toggle switch. It can all be done harness side.
Is you lower radio hose
Is you lower rad hose cool when the system is hot?
Avantugofast
07-16-2008 11:01 PM
mktbully
11-08-2006 04:27 AM
