For the PC-16 users, what N75 do you use, and what is your max, constant psi?
I have an ECS n75, I think I should probably be using stock, as well, I have a big FMIC with silicone but only stock TB hose, and stock inlet hose.
AudiWorld Uber User
it's more around 20-21 when the temp is around 50F. I don't know what to make of that N75, I've never used it. Pressure test the intake to 25 psi. I wasn't happy until I could get 30 into mine without hearing a leak.
about things like that happening? If the boost is hunting or wandering, is it most likely a boost leak? Sounds like it would be to me.
Where is the best place to get info on pressure testing?
AudiWorld Uber User
you'll get surging (bouncing boost) if you load up the engine too much. Like if you floor it at 2500RPM in 3rd gear. There isn't really a common place for leaks. Until you pressure test the intake, suspect everything.
SolidFish
Rocky Mountain Discussion
02-25-2008 06:43 PM
Kapoosh1
13
09-25-2005 05:39 AM
SilverA4Fun
03-25-2004 05:43 PM
