People who've had to replace Throttle Bodies...
What were your symptoms and did you throw any codes? I think mine is dead and I'm just wondering what happened with other peoples. How hard is the switch?
Loss of throttle control....
Like it just doesnt work anymore. Car also stalls or the throttle will comeback.
Also got these codes
4 DTC's Found:
16505 - Throttle Position Sensor (G69): Implausible Signal
35-10 - - - Intermittent
16487 - MAF Sensor (G70): Signal too High
17953 - Throttle Valve Controller: Malfunction
17952 - Throttle Actuation Pot (G187): Signal too Large
4 DTC's Found:
I had to...
I have a 97 1.8t and the little electric motor in the throttle body died. this threw a code having to do with the throttle body. I knew something was wrong when i had absolutely no boost. this happens becasue the computer drops you boost to something rediculously low when it senses the problem.
Very easy to switch. took 30 minutes.
