PES G2 Owners: Temp Plate Development Underway
I have begun drafting an initial design--it will be about 1.25" thick, meaning you'll either have to cut a hole/ put in a bubble in the hood (which done tastefully actually wouldn't be bad, actually) or the easier method---extend the coilpack harness and mount it to the side.
Initial design will be to have coolant running through vanes that will sit in the boost stream; entire plate will bolt in between the manifold and charger. Reservoir will be hooked up to a constantly-flowing pump (a la VR6 pump---cheap) to pump the coolant through the plate, then to a cooler mounted down below in the airstream. Not unlike an oil cooler. This will actually be much like the water-to-air intercooler I run in one of my 16V turbo setups. Also had idea about another cooling modality wherein a separate catch basin could hold dry ice for additional cooling on 'race day'. Have a buddy of mine back up in Seattle who is an automotive engineer (subcontracted) who swears there is a way to make one using the AC system flow. Of course, that would have to be a charged system and would get a lot more complicated; but also has the potential to make things quite cold in there....
Ideas, suggestions......
i'm intrigued by the A/C cooling setup...
that would be a really slick setup if you could get it to work. Wouldn't necessarily be that difficult either in all honesty... well, if you forgo the A/C in the car and just reroute the lines to the plate.
Look forward to seeing some progress! Not that it'd affect me any, but still... very cool!
One suggestion about fitment.
Even if you extend the CP harness and relocate, you will still probably have to bubble/cut the hood. It's not the body of the charger that is the problem...it's the nose and pulley. Look at our hood line from the side, it's a fairly steep drop....that means less clearance in front than in the back. The big problem with that is the hood latch also happens to be in the way Good luck!
GorTT
24
01-18-2008 07:34 AM
