Pics of my painted calipers
I used the paint from <a href="http://www.legendfive.com/">Legend5</a>. It comes in two cans that you mix, then brush on. After mixing the two, it's VERY thin. I left the calipers on the car when I did it. Be prepared to wipe up any paint that gets on the rotor, and make sure you have something on the ground to catch the drips. I went around the car 3 times, and there was plenty of paint left over, I even painted the backs of the brake pads. Then I let the car sit overnight.
<img src="http://pictureposter.audiworld.com/12130/brakes_fr.jpg">
<img src="http://pictureposter.audiworld.com/12130/brakes_rr.jpg">
Don't get any paint on the piston/seal assembly, or the slider assembly. If you paint it on the car, dont let any paint get on the rotor or pad surface. I had some thinner close by to remove anything that got on the caliper. I just painted the front and top of the caliper, basically just the visible parts. I also painted the caliper bracket.
<center><img src="http://pictureposter.audiworld.com/227/jamesrcaliper.jpg"></center><p>James R.
2001 A4 1.8TQMSXP (Koni Coil-Overs, Neuspeed 19mm Rear Anti-Sway, StopTech A4 Brake System, SS Brake Lines, Pagid Performance Friction (soon), Oettinger Pedal Set + Dead, Oettinger RE's 17x8, Yoko AVS Sports 225/45/R17, European Xenon Housings, Bailey BPV & RS4 Grill)
I would like to paint my brakes black, like my car.
Any tips, suges.,
Regards,
Jonathan C
BTW im working on the Co op paper right now.
thanks for the call.
Any tips, suges.,
Regards,
Jonathan C
