Post your project A4
#24
Back in 2000-2001
<img src="http://pictureposter.audiworld.com/1346/slo-3.jpg">
<img src="http://pictureposter.audiworld.com/1346/0013.jpg">
Now - Just used for track.
<img src="http://www.centralvalleyspeed.com/photogallery/albums/userpics/10093/driver-side-01.jpg">
<img src="http://www.centralvalleyspeed.com/photogallery/albums/userpics/10093/enginebay.jpg">
Mods
ENGINE:
ATW block bored to 83.5 mm
ABA 2 liter crank
JE 8.5:1 Pistons
Pauter Rods
Ported AEB head
RaceWare heads
Schrick 252 cams
1mm over intake valves
Stock size exhaust valves
High lift, high rate valve-spring set with Titanium retainers
VR6 throttle body
Custom Intake Manifold
034 Motorsport Wrinkle painted valve cover
034 Motorsport Coil Heat Shield
034 Motorsport Solid Engine mounts
Stern Snub Mount from Pure Motorsport
Oil Catch Can drained back into the oil pan
Odyssey Light Weight Racing Battery (PC680MJT)
Custom Billet Battery Holder
Custom Power Steering Cooler
NewSouth Performance PowerGasket Plus
Aftermarket Electric Fan
TURBO & EXHAUST:
Full-Race.com manifold
GT35R with .82 ar
Tial 38mm waste gate
Wastegate dump tube
3" down pipe
3" test pipe with dump outlet
3" exhaust to Magnaflow muffler
Custom Evolution Racewerks FMIC with Garrett 24x10.5x3.5 core
2.5" IC pipes
Tial 50mm BOV
HKS Filter
FUEL & TUNING:
034 Motorsport IIc stand alone with 4.5 bar map sensor
96 lbs low imp injectors
034 Motorsport fuel rail
SX adjustable fpr
-6 AN fuel feed line from tank
Bosch Motorsport 044 fuel pump from 034efi
HKS EVC4 Boost Controler
Tuned at 32psi on 110 octane
TRANSMISSION and DRIVELINE:
1.8 trans
Custom 4800 lbs dual diaphram 6 puck clutch
Spec Billet Steel flywheel
034 Motorsport solid trans mounts
Stern rear diff mount and rear diff bushings from Pure Motorsport
BRAKES:
Pure Motorsport Stage 1 kit(front)
SUSPENSION & WHEELS:
Koni shocks(regrooved fronts)
Intrax S4 Sport springs
OEM non sport front sway bar
OEM sport rear sway bar
OZ SL 17x8 wheels
BFG Drag Radials 225/45/17
Wheel stud conversion kit from Eurocode Tuning
INTERIOR:
Cobra Suzuka kevlar race seat
Sparco Racer Steering Wheel
JH Motorsports Solid Short Shifter kit
JH Motorsports Shift linkage upgrade
JH Motorsports shifter stabilizer bushing upgrade
Stewart Warner Gauges (Boost, Fuel Pressure, Oil Pressure and 3.5" 8K rpm Tach)
Autometer EGT gauge
Innovate Motorsport LM1 Wide Band
EXTERIOR:
Painted Lowers
Modded S4 Front Bumper
Custom Fiber Images Kevlar Hood/Fenders/Doors
Fiber Images Carbon Fiber Trunk
THNIGS TO COME:
Twin Scroll GT4088
Air/water intercooler
Custom catch can
Audi DTM paint scheme
Mods
ENGINE:
ABA 2 liter crank
JE 8.5:1 Pistons
Pauter Rods
Ported AEB head
RaceWare heads
Schrick 252 cams
VR6 throttle body
TURBO & EXHAUST:
GT35R with .82 ar
Wastegate dump tube
3" down pipe
2.5" IC pipes
Tial 50mm BOV
HKS Filter
FUEL & TUNING:
SX adjustable fpr
1.8 trans
BRAKES:
OZ SL 17x8 wheels
INTERIOR:
Autometer EGT gauge
EXTERIOR:
Painted Lowers
THNIGS TO COME:
Twin Scroll GT4088
Custom catch can
