power steering fluid too low to register -- it this serious?
#13
And do it again in a week or two until your whole can is gone. Kinda a waste, but so is 1/2 can of CHF11S just sitting on the shelf.
A complete flush would mean disconnecting the return hose from the pump to the res and dumping the dirty fluid into a container as you crank it (spark plugs disconnected) and fill with clean fluid as you go until it runs out the other end clear.
#14
Pentosin is the manufacturer for the Audi factory fluid part number G 002 000. The Audi 5000 up to the 1989 models used the Pentosin CHF 7.1. In 1989 they went to a Pentosin CHF 11S which is a synthetic version with an improved temperature range. You can buy it at the dealer for more just to have a bottle with the VW/Audi logo. Or you can get it elsewhere for less in its manufacturer bottle. I don't know what Pestone is. Your friend probably put the Pentosin 7.1 in a car that takes 11S. Ask the dealer, they will tell you it is Pentosin.
J
J
#15
or instead of disconnecting the spark plugs just pull the fuel pump fuse. I did the power steering flush and pulled the fuel pump fuse...much easier and quicker than disconnecting the coilpacks.
J
J
oatzel
02-24-2004 08:52 AM
RobertV
9
10-26-2003 07:34 AM
