problem after filling up with gas
This problem only occours when i fill the car up with gas. Right after I filll up (which is almost 50 with current gas prices) when I goto start the car it wont start. It tries to turn over but cant like the car is out of gas. If i press down the gas pedal to give it gas it will start after a short period of time, but still not even a normal turn over. Once it starts it runs like crap and the rpms wont remain constant at idle. after i drive for like a minute its back to normal.
anyone know what this could be
99 a4 qtm with 148k on it.
Often caused by "topping off" the gas, It eventually ruins that filter or valve*edit*
also called a carbon canister<ul><li><a href="https://forums.audiworld.com/a4/msgs/1787853.phtml">push</a></li></ul>
Purge Valve
Did mine last summer - EXACT symptoms you are experiencing. Part - ~$60 at stealership, time to replace ~5 minutes. My recollection is that it was near the airbox. Good luck.
Rich_W
01-28-2003 11:26 AM
