quattro driveshaft play with rear differential
should the connection between the driveshaft and the rear differential be solid, or should there be some rotational play?
Not sure what you're saying. Does the center driveshaft have twisting play at the rear dif? Usually, thier failure is noted from thier front/rear play, and it "thunks" under hard acceleration. Or the center bearing goes.
and followed the clicking sound to just ahead of the rear differential. I could turn the drive shaft about 5-10 degrees in either direction by hand.
Then I'd agree with you as long as it's not differential play you're dealing with.
I do have a center driveshaft for a 1.8TQM if you're interested. $300.
center rear jacking point? Front is on jackstands, need to get the rear up. Diff case strong enough?
Bimmer Needs Reverse
09-27-2008 08:15 PM
Don@STaSIS
01-03-2006 08:45 PM
dtompsett
12-16-2004 04:03 AM
