Quattro wheel spin
I'm trying to understand one aspect of the quattro system. I understand if only one tire has traction, then that tire gets the power. If all the tires lose traction then all spin, if there is no traction control? Is that right? So, in snow or ice one tire would not spin, but all 4 could?
will just hold power back on all of them. In rain i can take off and when the torque peaks (with ESP off) i can get all 4 to spin but with ESP on it will flash.
So that means there will always be power to an "axle" regardless of the conditions. It can not send 100% of the power to any one axle.
Then, wheelspin is eliminated (side to side) by applying the ABS to the appropriate (slipping) side. Power is not redirected. If both sides slip, I think the wheels will just spin uninhibited by the ABS.
Typically, on an icey surface, you'll just break loose all four tires, but with four tires scrabbling for grip, you tend to get moving an awful lot quicker than if you just had one tire looking for grip.
Summer tires+freezing temps= hockey pucks for wheels. The car basically rotated in about 1 car length.
I was just experimenting with the amount of traction I actually had w. the summer tires (michelin Pilot SX). Turns out not very much...
jjomalley
10
12-12-2006 10:42 AM
For those interested in the relationship between Quattro, ESP, EDL, ASR and ABS, here is a brief ...
Jet Jockey/A4 Pilot
Canadian Discussion
10-06-2003 06:55 AM
Jet Jockey/A4 Pilot
10-06-2003 02:22 AM
quattronirvana
11-06-2002 02:18 PM
Wir fahr'n auf der Autobahn
07-12-2000 01:13 PM
