Question about citylight wiring ...
<center><img src="http://pictureposter.audiworld.com/45776/img_0008.jpg"></center><p>There are three wires going to my corner lights. To which one do I connect the citylight wire and how ?
thanks
thanks
i didnt want my corner lighs on at all times so i cut the wire that turns them when when u turn the lights on and just connected that wire to my city lights, so now if i turn my lights up 1 time i go just city lights nothing else and if i put on my headlights i get low beam and city lights, use a tst light and u can figure out which wire it is....hope this helps
In the corner light wiring harness, slice open the black cover about 6" up from the plug, and cut the gray wire. Take the end of the gray wire that goes towards the plug and connect it to the yellow wire that goes to pin#3 of the plug. Take the other end of the gray wire (that goes towards the switch inside) and connect it to the yellow wire that goes to pin#8. Strip, Solder, and heat the shrink tubing (I didn't heat the larger shrink tubing, as this was more for looks)
ctny.audiworld.com/mark/s4
mmart6545
11-09-2004 03:54 PM
JustJeff
05-04-2004 06:09 AM
ex-quattro PETE
05-29-2003 11:10 AM
George @ BostonAudi
07-11-2001 07:42 AM
