A question about headlight washer jets...
They don't seem to work at all. Should I be able to gently pull them out, and if I can not does that mean they are ceased or broken? Thanks.
98 2.8
Matt.
98 2.8
Matt.
She stood outside the car, and I was demonstrating how the headlight washers work, and my friend pointed out that they didn't work!
Other than feeling foolish in front of my friend, I learned that I had to get my washers fixed. Actually what had happened was that the washer pump cracked and had to be replaced. So it wasn't generating enough pressure to lift the headlight washers.
-- P.
-- P.
also, as the others said, you have to have your headlights on for them to work. And, you can hold it for a split second and they won't fire. If you hold the stalk back a little longer both the shield and light jets fire.
<img src="http://pictureposter.audiworld.com/10901/dscn2357.jpg">
