Question about rear sway bar bushings...
My rear sway bar bushings get squeeky every 6 months or so. I have to take off the bushings, rub some grease on them, and re-install everything.
Is this normal?
Should I be using something other than the bushings that came w/ my Neuspeed rear sway bar?
What type of grease should I be using? Right now I'm using Mobil 1 red grease.
Thanks!
Is this normal?
Thanks!
I only had one instance where mine has squeaked in the 2 years I've had it.
It was pretty cold out so the bushings (red) must have shrunk.
I used a grease gun with a small grease needle to inject the M1 grease around the busings as much as possible. I wasn't up for disassembling everything in my driveway in the cold.
That worked well for me.
Good luck.
Good luck.
Try to get as skinny one as possible to get between the busing and the sway bar.
Just be careful....they break easily.
The one picture is pretty thick and will hold up to some hard poking around the bushings, but just won't get as deep.
Heck, just get one of each and you'll be all set.<ul><li><a href="http://www.thetoolwarehouse.net/shop/LNC-5803.html">GGN</a></li></ul>
KO4IAIN
04-08-2006 11:02 AM
BigMouse
10-16-2002 02:40 PM
