Question for the experts of MAF/boost/channel 32 logs...long
2001 1.8T Tip, the car use to have a K&N, I replaced it with OEM.
I got a cel (lean on all,when the car is cold) so I started logging (just got my vag) doing a lot of STFA, and here are my results, (PLEASE confirm):
I am getting boost requests of ~2130 mbar
actual boost closely follows.
My Air Mass In BEFORE cleaning my MAF max:128.58 (socond gear pull)
My Air Mass In AFTER cleaning my MAF max:134.50 (third gear pull)
My channel 32 BEFORE cleaning was 15.6 for Partial Throttle
My channel 32 AFTER cleaning was 13.3 (so far) for Partial Throttle
I cleaned the MAF by soking it in 99% alcohol for 1h and sloshing it a bit.
BUT, my guess is that the Ffffing MAF is still not what it should be
And with a boost request of 2130 which is 16.385 psi I should be getting around 170 g/s of air
Am i correct ?
Thanks for any help!
Am i correct ?
The new MAF works perfectly the second adaption for group 32 kept going down and after 15 or 20 minutes of driving it went down to 4% it will probably go down further with more driving.
Thanks to every one that helped.
PS: the MAF was refurbished from a local dealer. $110 CAD, with an additional $35 deposit for the old one. If I bring the old one back, I get the $35 back.
KevinLV
14
05-24-2004 01:01 PM
alleuroS
09-18-2003 11:54 AM
