Question regarding neuspeed sway bars...
I'm thinking of getting neuspeed rear and possibly front sway bars. I've heard the rear 19mm bar gave good results by causing more oversteer, but would adding the front bar counteract this result?
that's a poor way to balance the car out. Really you should try to fix most of the, "problem" with suspension and proper alignment. What's left can be tuned with some more rear bar...I have mine set to soft 19mm piece and it's very nice.
Regards,
James R.
Regards,
James R.
The car is a lot flatter thru turns, and definitely has less understeer. I already had the sport package, and I'm very pleased with the difference the bars made.
I forget the diameters, but I think they are a little bit less aggressive than Neuspeed bars.
I would also suggest a strut tower brace, if you haven't already done so.
3Scanner
07-07-2005 08:21 AM
Phil
01-19-2002 08:00 PM
Neo1
08-03-2001 11:18 AM
T-28-Quattro de VT
06-08-2001 08:27 AM
