Question for those who've installed the basslink? ........
I've heard it's very easy and i'm sure it is, i just can't figure it out. I've heard i can hook it up through the rear speakers, do you have to splice into the wires going to the speakers? Also, how do you get the power wire up to the battery? Lastly, was it sopposed to include the power wire with fuse, ground wire, and that other wire you need? Thanks alot for your responses, it will be a great help which is much appreciated.
you need to get your own power lines and fuse. Run the lines up along the floor runners, into the engine bay and to the battery
The whole stereo wiring harness goes right to the cd changer so you can tap into line level or speaker level wires.
PeteW
02-04-2002 02:09 PM
