Question: Tire Pressure
on your individual vehicle. This only makes sense right? The tire manufacturer has no idea what car it's going on. Most guys running 18's are running 37-39 psi.
AudiWorld Expert
If your car has a max speed of 130mph, does it mean you should only drive it at that?
Max PSI indicated on the tire is the maximum this particular tire was designed to handle, but it has nothing to do with what you should be running. What you should be running depends on the particular car that you drive, but you should never go above the max PSI indicated on the tire.
rexti_98
9
03-04-2004 10:43 AM
