questions on possible MAF sensor problem...
My car has been idling funny and having momentary periods of reduced power while dirving around town. After searching around the archives for a while it seems the MAF sensor could be ther problem. If i were to unplug the MAF connection, It should run consistently but either very lean or rich, not sure which... Will this work as a diagnostic step? Any other ideas to try?
during wot since it used the maf to help lean out the car. At part throttle and idle it wont matter much because the ecu still uses the 02 sensor to keep the car in check.
Removing the MAF from the air box is simple. Just take the air box off the car and look inside of it. You will see the MAF is held on to the box by a couple of screws. Just unscrew it and take it off. Make sure you put it back on the same way because the air has to flow in the right direction.
with a rubber boot and a set of wires coming straight up. Sorry its been almost 4 years since I have had a stock air box in my car.
Jestapilot
01-19-2005 08:43 PM
MyKey
06-06-2002 01:58 PM
