Quick ECU question.
Old 08-27-2005, 09:21 AM
New Member
1.8Tizzle's Avatar
Default Quick ECU question.
Will an ECU from an Automatic 98-99 Passat (557P) work correctly in a 97 A4 5spd. Quattro? Both cars are 1.8t, and the passat is nDBW also i assume, based on the year. I am just worried about the difference in transmission. Will this be a problem?
thank you!
-Jonah K.
Old 08-27-2005, 09:42 AM
BSCA4's Avatar
Yes, Passat nDBW ECU are same with Audi A4 nDBW.
Old 08-27-2005, 10:36 AM
DON2.0T's Avatar
no. auto to manual doesn't work
Old 08-27-2005, 10:42 AM
JAFO's Avatar
Default iirc you can recode the ecu for a manual....
but you'll need a vag-com or a trip to a dealer.
Old 08-27-2005, 10:59 AM
starting ...'s Avatar
2nd
Old 08-27-2005, 11:20 AM
Keeper of the Cash
Nate (ETKA+Scumbag)'s Avatar
Yes, with VAG-COM use code 06201 to recode the ECU.
Old 08-27-2005, 11:24 AM
Banned
4Rings::G2 boosted::'s Avatar
Of course it does. You can recode the ECU. I've done it myself.
Old 08-27-2005, 11:40 AM
New Member
1.8Tizzle's Avatar
Default Re: Quick ECU question.
So then the general consensus is that it will work, but not without recoding? Would a passat/a4 ecu from a MANUAL car work without recoding? I did previous research on this forum and some people seemed to think that the transmission type was 'soft' coded in the ecu, so it could operate both an auto and manual car. My current ECU is completely screwed so i dont know how i'd get the car to a dealership.
Old 08-27-2005, 11:42 AM
Banned
Default It will work without recoding, but you'll get a CEL and an error code
The error code is for lack of communication with the tranny controller, since the auto trannys have one and manuals do not. However, if you ignore the CEL the car will be perfectly drivable.
A manual to manual swap doesn't require a recode, assuming the two ECUs are from compatible years.
Old 08-27-2005, 12:14 PM
New Member
1.8Tizzle's Avatar
Default Can a volkswagen dealership do this?
My Audi dealership isnt exactly 'local', theres a VW dealer much closer, would they be able/willing to recode it for me?
Quick Reply: Quick ECU question.
