quick...I need suggestions...
Dealer just called & said my allignment is perfect however the car pulls to the left alot. What could it be? He said he would road test the car and call back in 30 minutes. He will probably say its fine !@#$%!!
I don't know how much you weigh... but if you're a big guy, sometimes when the car is aligned perfectly on the alignment rack, it will still tend to pull to the heavier side on the road.
would it pull the opposite way? Wouldn't a tire rotation on an S4 consist of moving the fronts to the rear and vice-versa? If the tires were worn unevenly on one side causing the pull and they were rotated front to back, then they would still be on the same side. I'm just assuming that the tires on the S4 are directional.
