quick question for all you physics people...
when braking at full force, will a car with bald tires have longer skidmarks than a car with brand new tires given the same speed and conditions? thanks!
.....tread and the other does not. I would think the one that has tread would take longer to stop due to a less contact area(longer skid mark).
In a short distance, the bald tire will be shorter.
On a very hot day, or stopping from a higher speed, the bald tire will heat up more, and retain its heat, and melt, hence, no traction, and will slide. The tire with tread will stay cool better, as there is airspace between rubber contacting the ground.
In general, the tire with tread will make a longer skid mark, but sometimes it goes the other way, such as above.
so, less contact with the ground shouldn't make your stopping time worse. Generally a tread pattern is a good idea..
a bald tire will only be better on perfect, dry pavement. The tread helps will all less than perfect conditions.
Ever worn the soles of a pair of shoes down? you could stick great to glass or something like that, but if you introduce some saw dust or water, you're screwed.
so.. it depends.. the bald tire would win in perfect conditions (dry.. track) otherwise, the new tire would do better
note, i'm not trying to say you should track your car with bald tires.. that a whole other story.
even though i has more contact area, but remember, not a whole lot more because at each instance, only a small patch of rubber is touching the ground.
tire compound is what makes the tires stick to the ground, not just because of contact area
If balding tire refers to an aged tire, yes, the rubber will not stick as well as fresh rubber. It's then possible that the bald tire would lay some serious skids vs. the fresh rubber.
