Are ramps or jack stands safe? I don't have a garage or perfectly level place to use them.
Old 01-17-2002, 08:07 AM
BoulderA4's Avatar
Old 01-17-2002, 08:12 AM
Member
Bill In SoCal's Avatar
I rotate my tires and change my oil in empty shopping center parking lots.
Old 01-17-2002, 08:16 AM
BoulderA4's Avatar
Do you use ramps or stands? is there a difference in saftey/height? TIA
Old 01-17-2002, 08:19 AM
Member
Default I prefer stands. I got a 2 1/4 ton floor jack with 2 stands from Sears for $50 good deal IMO. I've
used ramps before but feel safer under the stands. However they are both fine. If you use ramps makes sure to put chocks behind the rear wheels and yank up the e-brake.
Old 01-17-2002, 08:20 AM
Member
Silver Streakin''s Avatar
Default Rhino ramps and the like are great and safe, if used properly. If you use jack stands in the correct
<center><img src="http://pictureposter.audiworld.com/116/a_hedin_rhino_ramps.jpg"></center><p>place, you're fine. You shouldn't use a jack only and then crawl under the car. I've watched my 2 1/4 ton floor jack slowly drop and would never get under a car with just the jack. I use the ramps unless the job requires taking off a wheel. Then, jack it up and use the stands. Personally, I don't like jack in the tool box provided. I've never used it and will only use it, if it's my last choice like getting a flat.
*pic stolen from Andy Hedin's pic poster*
Member
what is the name of those OEM audi rims in that pic.
Old 01-17-2002, 08:21 AM
BoulderA4's Avatar
Are the stands high enough to do things like changeing sway bars, bpv valves etc?
Old 01-17-2002, 08:24 AM
Member
Haven't had to do that yet but they go pretty high. I 'm as High as ramps that's for sure.
Old 01-17-2002, 08:26 AM
BoulderA4's Avatar
I believe those are the 'swing' wheels
Old 01-17-2002, 08:28 AM
Sourdough Josh's Avatar
Stands should be safe when used in pairs. I've had my jack slowly fall as well.
Quick Reply: Are ramps or jack stands safe? I don't have a garage or perfectly level place to use them.
