rar brake pad replacement on 97 a4 2.8 quattro...special audi tool price?
<center><img src="http://pictureposter.audiworld.com/116/a4_brake_piston_tool.jpg"></center><p>
....turn using a socket wrench and apply as much pressure as you can. I then grabbed my C-clamp and used that just a bit to apply some more pressure. Then back to the tool...then back to the C-clamp for another quick squeeze.
....unlike the fronts where all you need to do to compress the piston is push, the rear's (as you know) require pushing and turning.
The C-clamp on the rear won't compress the piston much, and you have to be careful you don't force it too hard or you might damage something. But I used it to apply more pressure than I could with just the piston-turning tool. Good luck!
TittieTwister
11-23-2005 05:25 PM
