Really need help on this one....
#11
That's probably bad too, but not related to the poor running. You really should find someone with VAG-COM to get a better read on the codes, but the MAF is probably the place to start testing.
#14
Ok, I replaced the MAF with exact part#. Nothing changed. I had my dad look at it with me. We checked all the plug wires, there was a small amount of oil in well 1, 2, and 3. Mostly 1. Wiped it all out thoroughly and cleaned the boots. Bank 2 was dry. Reassembled, still no improvement. The coil packs and plug wires are bran new. After wriggling every wire and plug under the hood, somehow there was a vast improvement in the frequency of the problem. It almost never does it randomly now, but around 5,000 rpm's, it will start running rough and continue running rough, only for 30seconds or so now. Before it would run like that up to and over ten minutes at a time. PLEASE........ WHAT AM I DEALING WITH HEEEERRRRREEEEE.............. So frustrated..........
#17
As a general FYI - we are about one post away from me not being able to see this branch of the thread due to limitations with this crappy vB software, so I may not see/answer subsequent posts. If there is a resolution, please post it as a child of the original post (go to the op and click "quote and reply") Thanks!
Dizzyhawk
05-31-2016 11:17 AM
audidream2
09-04-2012 01:46 AM
PhaseP
12-07-2004 07:07 AM
