Rear Brakes - 3 sets in 50k miles!
I just had my third set of rear brakes replaced...this past time it was metal-to-metal. The fronts still have plenty of wear left. I shift a lot, and never stay on the brakes longer than I have to, but the rear wear is unreal!! The dealer says it's because I'm a good driver, but I think it's a load of CRAP!! Also, the dealer said that there is a wear indicator light that is supposed to signal when the brakes get low...guess what? no light...and I had to replace both rear rotors and pads this last time! Any ideas? What about some quality aftermarket calipers/rotors/pads?
Good thought; in 83K miles on '98.5 Avant rear vs. front wear NOWHERE this different
This in hilly western PA/WV terrain.
RE the pad wear sensors: far as I know the sensors have to be mounted in the pads, and the wire connected to the car wiring harness.
To check e-brake engagement, drive on a striaght section of road for a few minutes, then pull over and stop using as little (if no) brakes. Touch the front and rear wheels; if cool, try a light touch of the calipers. If rear calipers are very much hotter than the fronts, the e-brake is hangfing up (possibly the actuating cable needs adjustment).
there is a easier way to test e-brake engagement.
put car in neutral and make sure you dis-engage e-brake handle fully. Push car back and forth, if there is significant resistance (hard to push once you get car moving) the brakes may be seated incorrectly or the e-brake may partially be engaged. This is a trick I learned from my cousin, who is a mechanic and runs his own shop.
CTA4AVANT
04-12-2005 03:32 PM
[not Steve] Trac
12-05-2000 09:51 PM
