rear brakes
I read the tech article on replacing the rear brake pads, which was helful, but i still cant push the caliper piston back in. I bought the right tool, but still nothing. It turns, but it wont go back in. Anybody else run into this problem?
I couldn't get my 3yo rear caliper pistons to go in either without the use of this tool. I don't care how big your C-clamp is...it won't work all the time. Mine sure didn't. Have them do it at a Meineke or similar bonehead shop. They will almost surely have the proper tool for the job...which is hard to screw up.
AudiWorld Expert
Make sure your cap is off the reseviour in the master cylinder.
Also, you might try alternating the use of a c-clamp and then the tool and back again a few times.
We were able to get mine done with a spanner wrench and the c-clamp this way.
Reggie
98.52.8QMS
Reggie
98.52.8QMS
you won't push the dirty fluid back into the master cylinder(potentially)
Also, I have found that it is easiest to use a power tool, such as a drill or impact gun if you have one to turn in the piston using the correct tool, 3131 - BRAKE CALIPER SPANNER Priced at only $25.53, from <a href="http://www.baumtools.com/"> Baum Tools</a> (no affiliation)
Makes life SO much easier!!
MRS difficulTT
05-13-2005 07:27 PM
mjbrox
03-27-2003 08:35 AM
fabva
07-21-2001 07:11 AM
