Rear door panel removal instructions
panel is attached to the door with 4 phillips screws:
(1)
2 small screw are screwed into each upper corner of the door (only visible with the door open)
(2)
inside the door handle is a screw hidden, if you look around you see it holding the small piece of the handle from the inside. remove that screw and try to pull out the small lower section of the door handle.. that things is TIGHT in there and you feel like you are breaking it.. it needs some force and wiggling but will come out.
(3)
after you removed the small piece the last screw will emerge right behind the now missing cover. remove it!
(4)
the panel will now come off if you PULL UP on it. gentle pulling as you will have the speakers, the window switch and the door handle still connected
(5)
the door handle is a hook type wire that is secured with a little aluminum "U" that can be pulled off. all the wires can be disconnected
installation is in the reverse order, make sure to grap a hold of the door pin first before sliding the panel back down. once the pin is in the whole you are set to lock the panel back into place
(1)
(2)
(3)
(4)
(5)
Bisqueth
03-31-2009 02:24 PM
Esfore
05-16-2002 09:10 AM
Tim NYC (E28 M5)
11-09-2001 05:53 AM
