rear rotors
Old 11-11-2004, 07:49 AM
AWUSER1976's Avatar
Default rear rotors
i got wheels off of another guys a4(98 A4), the rear wont mount up on mine(97 1.8t FWD) because the bearing center hits the wheel, is the AWD rotor different?
is there any option to fix this?
Old 11-11-2004, 07:52 AM
Head Cat Herder
Kris Hansen's Avatar
Default HUH? That's not right... the hubs on the front and rear should be the same diameter...
Is it the dust cap which hits the wheel, or the actual lip on the hub that is the problem?
AWUSER1976's Avatar
Default Re: HUH? That's not right... the hubs on the front and rear should be the same diameter...
its the actual metal lip on the rotor taht surrounds the bearing that hits
Old 11-11-2004, 07:53 AM
BSCA4's Avatar
AWD rear rotor is different with FWD. But rim should mount up OK.
Head Cat Herder
Hits where? you sure these are Audi wheels?
Old 11-11-2004, 07:54 AM
AWUSER1976's Avatar
they came off of a 98 A4, not stock wheels, aftermarket
Old 11-11-2004, 07:56 AM
Head Cat Herder
Odd. I can't see how they could fit on the front but not the rear.
Old 11-11-2004, 07:57 AM
BSCA4's Avatar
Default You may have a hub centric ring that smaller than Audi hub. Check to see if ....
there is a ring mounted in the rim hub
Old 11-11-2004, 08:00 AM
AWUSER1976's Avatar
Default Re: Odd. I can't see how they could fit on the front but not the rear.
<center><img src="http://69.0.158.19/live/thumb/N100052808ZIM.JPG"></center><p>the rear rotor on mine look s like this:
it hits the ridge around the bearing
Head Cat Herder
But the front should have the same 'ridge'.
Quick Reply: rear rotors
