Rear spring cracked
My rear passenger side spring cracked when I went over a speed bump. When taking it in to get a price quote they told me I need to have both struts replaced in the rear. They said it would cost 935$. Is it completely necessary to have this done or can I just have the spring replaced?
They are considered shocks not struts.
Pretty common problem if your car is subjected to salty roads.
When I replaced mine, I had to get the springs from audi, but saved some money by going with Sachs shocks. Also, if you can get your hands on a spring compressor, are patient, and careful, you might be able to tackle this yourself. Another possibility- you might be able to find the coil/spring as a unit. Then it is a straight forward swap.
Finally, I think Audi recommends replacing the case-hardened bolts when changing things up...Be sure to check if you go the DIY route.
87ninefiveone
04-15-2008 05:58 PM
esanmiguel
10-13-2006 09:27 AM
BoneStockS4
15
05-01-2006 06:46 PM
feakara
09-18-2003 07:53 AM
