Rear wheel bearings on '99.5 2.8q . Any tips ?
I have to replace the rear wheel bearings real soon . Car is a 99.5 2.8 quattro . Any helpful info about parts sources or special tools needed would be appreciated .
a comment.....
<center><img src="http://samstagsales.com/SirTool/st_b90z.jpg"></center><p>I've used the bearing press kit(Sir Tools Master kit B90) in the pic which has become an invaluable asset. I would just give Carson, at Riverside an email to get the bearing and collar bolt. This way your insured a reasonable quality level, as well as the correct parts associated with your vin.
You might consider having the factory service manual handy for procedure and torque specs. I would also put the bearing into the freezer overnight and keep it there right until installation. Make sure the hub housing is exceedingly clean and free of debris and corrosion. I like to wipe the clean surface of the press surface of the hub with a very light oil as a lubricant upon pressing the bearing in. Do not, under any circumstances let that bearing cant upon installation. It will quickly and certainly reduce the lifespan by half easily.
Regards
Regards
This is one of those things that is easier to just pay someone else to do.
Buy good bearings and take it to a good shop. I am all for DIY, but from my experience, it's not even worth getting dirty to do, same goes for exhaust work.
