Rear Window Auto Up mod article??
Anyone know where that rear window auto up mod article went? I looked through the tech articles, and did a search, but all I can find is that it used to be there but isn't anymore.
Here's an article, but it looks like you'll need a VAG tool to use it.
UPDATE: Looks like it only covers how to use to remote to open the windows, sorry.<ul><li><a href="https://www.audiworld.com/tech/elec33.shtml">https://www.audiworld.com/tech/elec33.shtml</a></li></ul>
... and it is nice, but I was looking to make the rear windows do the 1-touch-up like the front windows do when you're in the car.
use the link below for the steps to take the door and window regulator apart. when you have the window regulator, simply wrap a wire around pins 5 and 7 in a figure-8 shape. that's it. then plug it back in, reassemble door, and hold the window button down for 5 seconds and then up for 5 seconds to learn the new feature. after that, you should have one touch up and down. voila.
repeat on other rear door.<ul><li><a href="http://www.obdtool.com/onetouch/">http://www.obdtool.com/onetouch/</a</li></ul>
here's the link i was talking about. very very simple. you can ignore the link in my first post, that takes a bit more time.<ul><li><a href="https://forums.audiworld.com/a4/msgs/1271980.phtml">https://forums.audiworld.com/a4/msgs/1271980.phtml</a</li></ul>
Pscheoverdrive
10-10-2007 06:44 PM
McA4
06-02-2005 11:55 PM
I did the cheesy 1-touch up rear window mod this weekend and found it really doesn't work very well.
Silver Streakin'
07-22-2002 08:03 AM
