reasons for engine not to have increased idle at startup
My engine, after TT install doesn't seem to idle at the increased RPM everytime I startup. Is this normal, and just noticing after install, or is there something I should look at.
it doesn't always run the high idle. Maybe I am just noticing it for the first time.
Can there be any problems, from not having the higher idle? Or is this for convience only (like warm up the heater faster).
and it's a cold start, the car won't idle at the typical 1200 or so RPM. Also, I failed MAF will do this, but you would have a CEL if that were the case. If the weather is ok, then yes I'll be there tommorow and no I haven't washed my car.
JohnP520
04-11-2003 06:50 PM
