Recently bought 2001 A4 question on fuel economy
#32
come on fellas! I'm sure you're both right.
soldering is the best way to do it if you do it right.
Bosch can't assume that everyone who buys the universal sensor is going to know how to do things right.
I am an electronics repair technician. i repair mainly audio equipment but I can attest to the abominable soldering skills of your average joe.
its in Bosch's best interest to provide an easy repair so that people dont botch their bosch
flux is a problem in many cases with soldering, and thats why they make flux remover.
anyway, I ended up buying the bosch sensor from ecs that didn't require any crimping or solderng. simply because i want to make this job a simple one while being more economical than buying the OEM part.
also got the differential drain/fill plugs and oil.
I'll post my results once the repair is complete.
i did experience a slight increase in milage after the techron fuel injector treatment. i'm getting 14.5-15 ave. mixed.
#33
My point is that we can't know this without knowing why Bosch has the requirement. Without knowing why, we can only guess. No one is disputing that soldering makes an excellent mechanical connection...but Bosch recommends that you do not solder. If we know why they recommend this, which we do not, then we can decide whether or not it is prudent to ignore this directive.
Just because the requirement does not seem to make sense is not solid logic to ignore it.
#35
I have a '97 2.8L auto quattro and it gets about 17 mpg city and freeway. I live in calif where the traffic is bad. I have changed the plugs, o2 sensors, MAF meter, differential, center diff, front differential, auto transmission fluid. I didn't get a significant improvement in mpg. I have a 12V 2.8 which is different from yours but I have come to accept the fact that our 2.8 just doesn't get good gas mileage. I have driven rental car and get much better mpg so I know its not my driving style
#37
On another note.....If I go to the alpha-bid.com and get the cable, does that mean I can download the free vag-com software and use that instead of paying the 230 bucks for their cable????
gwdayton
01-17-2013 01:47 PM
perfution
09-01-2003 05:41 AM
Cipher5170
06-28-2003 12:53 PM
