Recomendations on gasket sealer on 2.8 valve covers?
will it hurt to put a bead around the whole thing or should i stick with the small dollops in the corners?
<center><img src="http://i36.tinypic.com/2ignpcx.jpg"></center><p>Either:
1)Wurth DP 300
2)Factory D 454 300 A2
You might just put a small drop at each peak or corner.
Torque spec(cylinder head cover)-10Nm(7ft lbs)
If your concerned about oil leaks up there, you might check over the crankcase pcv and the suction pump.
Regards
1)Wurth DP 300
Regards
If you want to save yourself some money, go to NAPA and get a tube of Permatex black for $5. I just did my 1.8T gasket and it worked perfectly w/ no leaks at all. Only use it at the corners w/ verticals and areas indicated in manual. Don't put it all over the place as it will not seal any better and may actually be detrimental and certainly make it a pita to remove the cover next time.
tube. I blew through the PVC tube that attaches to the valve cover and it gave no resistance so I dont think I have pressure build up under the valve cover unless I have a leaky cylinder.
nasdaqer
04-24-2006 06:18 PM
BillLumberg
03-21-2006 03:45 PM
Bobby Kinstle
12-27-2003 01:07 PM
