recommendations on what MBC to run w/J31 setup
Its really hard to adjust unless you get the one that has ticks. May be. Its doesn't help with smoothing out the boost either. I think the ones built with the breaking and springs might help with the boost, or a boost machine. My boost is on and off hard.
<ul><li><a href="http://www.forgemotorsport.com/content.asp?inc=product&cat=0016&product=F MBV050">http://www.forgemotorsport.com/content.asp?inc=product&cat=0016&product=F MBV050</a</li></ul>
If you're going to run a MBC in parallel with the N75, you want a ball and spring type that does NOT have a bleed hole on one side of it (most after market do, to prevent the waste gate from getting stuck open)
VAST(vastperformance.com) is the only company I know that actually makes one like this, but you can mod an off the shelf ball and spring MBC by plugging the bleed hole.
