Recommended fuse and holder for Basslink install?
<center><img src="http://www.radioshack.com/images/ProductCatalog/ProductImage/270/270-1237.jpg"></center><p>I'm going to be starting a Basslink installation soon and wanted to check that I was getting the right type of fuse. I can get a 30 amp fuse for this holder, and it has 12 gauge wire. I don't think that's insufficient, but I wanted to check. And of course, crimp the ends of the fuse holder to my power lines from the battery and to the amp.
Actually, one other question on that note - if I'm running lines for the sub, should I keep those wires on seperate sides of the car? I remember reading that running power and signal lines on the same side could cause interference.
Thanks a bunch.<ul><li><a href="http://www.radioshack.com/product.asp?catalog%5Fname=CTLG&category%5Fnam e=CTLG%5F011%5F004%5F001%5F000&product%5Fid=27 0%2D1237">http://www.radioshack.com/product.asp?catalog%5Fname=CTLG&category%5Fnam e=CTLG%5F011%5F004%5F
I was going to run RCA from my head unit's output
It has a dedicated subwoofer output, and you can adjust the bass levels, cutoffs etc. within the head unit's software. And, a dedicated output has to be cleaner than a speaker-level output converted to line-level within the Basslink. So, I'd rather use that. But, I think it means I need to run the lines on opposite sides of the car. Just trying to see if I can avoid the hassle of pulling up two sides of the door trim.
RedBlackYellow
03-23-2005 09:05 PM
jfabes
10-09-2001 06:56 PM
Pelican Pete
06-18-2000 07:39 PM
