Relaying the headlites & have questions...
I already have the relays for high & low beams mounted on the driver side fender. I have run a (+) with fuse & (-) wires to relays from the battery. What I need to know is...
1/ Where is the best spot on the harness to tap for a trigger wire.
2/ Where can I tap the harness to connect the wires for the passenger side lights. I don't want to have to put in more wires than I have to. I would like to use the existing harness but where is the ideal place to tap it much less where is it located? Does the harness for the passenger side lay under the fans?
bballfreak
9
04-14-2019 06:59 PM
jamile222
09-29-2015 11:22 AM
