removing AEB cylinder head, how the hell?!
I'm trying to pull the cylinder head from a 97 1.8T. I've removed all 10 cylinder head bolts along with the belts and all hoses but the thing just won't budge. I've been banging a huge screwdriver into the gasket for 10 minutes but it's simply not splitting the head from the block. Am I missing something?
If you need to hammer at all, tap along the sides of the head.
Are you sure its only Ten Bolts - Are there any brackets the span the head and the block?
when i did mine it came right apart.
did you remove the bracket on the intake? i dont think it would hold the head in palce but it could. did you remove the intake?
