Removing Center Console-Rear Section
Audiworld Senior Member
I'm attempting to install a pop-up can/cup holder in the area behind the shifter and next to the parking brake. I've run into two snags while trying to remove the console:
The FAQ says to remove the two 14mm nuts behind the rear ashtray. No prob. It also says to remove a 14mm nut underneath the rear cup holder (the one beneath the armrest). How do I get this cup holder out without breaking something?
I also need to remove the plastic trim that covers the parking brake handle. I've seen a couple of threads here that vaguely describe removing a tab, but I can't find anything like that. I would love to have a complete, precise set of instructions for removing the parking brake handle trim.
Thanks!
--Phil
Thanks!
--Phil
Thanks!
--Phil
Thanks!
--Phil
The only bolt I recall is the one in the rear ashtray. Along with the screws that are in the sides.
The FAQ is correct. There are two nuts behind the ashtray and there is one below the under-armrest cup-holder. I got brave, and removed the cup holder by yanking it up firmly.
I fiddled with the parking brake handle for quite some time before discovering that the plastic locating pin was missing on my car... the handle slid right off with a good strong pull.
--Phil
--Phil
|skolnick
05-13-2007 09:01 AM
SilverB
04-29-2004 07:24 PM
