Removing, Cleaning and Re-installing K&N Air Filter - What a PITA!
Well;
Its just taken me an hour and a half to re-install the air filter after cleaning it, much swearing, 3 different sets of pliers, a magnet to retrieve the dropped clip (why do they always fall where there is no way you could ever reach them), a set of chopsticks (in an attempt to get the dropped clip), more swearing, cut hands and a lot of patience.
Also had to unscrew and remove the heat shield to get the air filter to sit perfectly before re-covering.
But it is done - K&N filter cleaned and re-installed. :-)
Took the opportunity to vaccume the engine bay in those normally hard to reach areas.
Removing and installing the air filter is certainly not an easy task on an A4.
I ran the K&N as well, but after all the MAF's problems that I read about I just went back to stock...no performance gains anyway...
and yes it is a bitch of a job...I needed a friend to help me as an extra pair of hands...
without dicking around with that one, it takes <2 minutes. If you do mess with that hard to get clip it can take forever
Jonny K
Audi Original "S" Cars
05-09-2007 04:37 AM
R32Mathieu
10-30-2003 01:52 PM
