removing lower grills
doing snub mount and im already stuck...the left came out with ease but the right wont...is there something holding it back. I dont wanna break anything but its being stubborn, just yank harder??
Usually they come out with a bit of tugging, but sometimes the clips are stubborn. There are 2 rigid prongs that grab the bumper on the outside (the edge farther away from the license plate). You want to pull on the other end of the grill (nearer to the license plate). If you have a really thin screwdriver or maybe a thin metal ruler, you can insert that between the "inner" part of the grill and the bumper to disengage the single clip that's approximately in the middle of the grill (again, on the side closer to the plate). That's for the driver's side. On the passenger side, there's a plastic tab on the inner edge that you can pull out with your fingers that flexes the clip enough that the grill will pop out. I don't know why they didn't just put one of those tabs on both grills.
Good luck.
Good luck.
I could pull the grill out far enough to wedge the screwdriver between the bumper and the grill on the licence plate side and then it just popped off like nothing
It doesnt seem to want to budge, it bends a little but thast all. I'm trying to pull out then up right?? the APR guide is a little confusing when they talk about it
twinturbo_808
Q7 MK 1 Discussion
06-25-2008 07:24 AM
MLOSU
11-21-2003 02:07 PM
neildiamond
09-04-2002 02:12 PM
Stage3
01-04-2002 06:53 AM
